c0-f24
  • mustafa
    • May 2025
    [Error Code] c0-f24
    I have a problem with Konica Minolta Di620 coppier, Error code c0-f24
    when I back to Di62 - ALL ACTIVE SOLUTIONS that
    " SOLUTION: Check to ensure that the AIDC sensor is clean and that the connections are good. If the code persists, replace the AIDC sensor "
    What is the "AIDC sensor"?
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: c0-f24
    It is the sensor that checks the density of the toner in the dv box.
    • mustafa
      Re: c0-f24
      I found it !
      Thank you fixthecopier
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Re: c0-f24
        When I mwould get that code I would usually have a piece of paper pulled up and stuck in the cleaning section.
