Konica Bizhub C280 C-22563 error code
  • rgalban
    • Sep 2010
    • 13
    [Error Code] Konica Bizhub C280 C-22563 error code
    I have a Konica Bizhub C280 with a C-2253 error code popping up, does anyone have any suggestions for a fix?
  • JustManuals
    • Jan 2006
    • 9919
    Re: Konica Bizhub C280 C-22563 error code
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • MILLER4157
      • Feb 2011
      • 48
      per the manual:
      1) Check the connector between M2-PRCB CN14 for proper connection and correct as
      necessary.
      2) Check the M2 connector for proper drive coupling and correct as necessary.
      3) M2 operation check PRCB CN14-8 (REM)PRCB CN14-10 (LOCK) C-2 to 5
      4) Change M2
      5) Change PRCB
      from my experience. this is usually due to a loose connector on the m2 side or the prcb side or a faulty motor.
      motor p/n: A0ED M100 00
