has any one any experance of setting up the port 9100 to print to the c360. i have never printed via this but have a new customer needing this function
If at First you don't succeed remove all evidence of ever trying!
To set up port 9100 you have to enable it from the administrator mode of PageScope Web Connection, select Network---TCP/IP Setting---TCP/IP Setting. Enable ldp from here and then specify the raw port (port9100).
once this is done you can specify the ip and port on driver side
i have attached the op manuals for network and print op
