How to set up scanner on C250 by host name?
  • tonychew
    • Aug 2025
    Some of the servers need the pcs to use dynamic ip instead of fixed ip. I can't scan if I set up by using hostname. Any solutions? Thanks!
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: How to set up scanner on C250 by host name?
    Make sure the 'host name' is in caps, also you might have to put in the dns settings.
    The gene pool could use a little chlorine.
    • SCHWARZ
      • Jun 2011
      • 47
      try setting the domain on machine.
