C450 Error Code FE03
  • mindhunter
    • May 2008
    • 146
    Hi EveryBody. I faced With a New Error Code on Bizhub C450 Copier. Few days ago I Set SMB Setting For Scannig and I was sure that PC is connected to the Copier and Copier could access to the PCs Folder.(I found this Via Direct scan To SMB and Refrence Key on screen). Everything was set and good But When I Push the Start Button Scan Proccess is started and Transfer Icon Appear On the Screen. After that Transfer Icon Never Disappear and I couldnt Switch Between Copy Or BOX or Fax Button On the Panel.it seems that Copier Is in Hang Mode. I didnt do anything.After 5 or 6 Minutes Copier Shows Me Error Code FE03. Does Anyone Knows That This Code Refers To what? Does Anyone Have Any Suggestion? Thank you All.
  • copierguru
    • Jul 2011
    • 27
    Re: C450 Error Code FE03
    never had this code before but this is what it means, hope it helps
    code means:
    asic10 timeout number of DMA under operation and transfer completion line 0 DMA_BO
    MFP control board (PWB-MFPC) or Copier Board (PWB-CF)
