Konica 7130 F-36-4
  • CWalls
    • Jun 2025
    Konica 7130 F-36-4
    Need help with this code F-36-4, recently replace a idler gear for the fuser unit after that it started showing that message.
    any help would be apreciated
    Thank you.
  • skumar
    konica7130
    hi
    f36-4 is open thermistor2
    skumar
    • CWalls
      thank's i double check it and the message is still coming up any idea?
      • dogsbody
        • Jun 2007
        • 289
        I don't muck around with these things the temp sensors fail if you look at them sideways and when the thermostat wears it will chew into the upper (heat) roller. Then you will have to reset the temp code.
        The force will be with you always.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Maybe you removed the fuser with the power still on, when you changed the gear? Now you have a code, you must resset the code in 25 mode to clear it.
          Now into Ip TV KODI Boxes
          • bushy
            • 34
            7130 f36-4
            go to 25 mode dip switch 3 bit 1 put in a 0
            • azherm
              F36-4
              F34, F35 & F36 codes must be reset using 25 mode.
              Dipswith 3, bit 1 is the fuser reset command
              0 is no
              And 1 is yes
              You must reset a fuser fault
              • cgeorge
                Mode 25
                I have the same deal going on with a Konica 1015. I am not a copier tech but our company is having me fix this copier since our local company was unable to fix it. I had to change the fuser. How do I get into mode 25? Dipswitch 3, bit 1, What is this and how do I do this?
                Thanks,
                Curtis
