cardreader
  • patrick045
    • Sep 2010
    • 38
    cardreader
    cardreader solutions about Konica pro 920
    The machine doesnot work because he need an card(reader)
    I tried to solve it with HDD format but still it doesnot disapear
    Please send me an solution if possible
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: cardreader
    Need to go into billing mode and disable the coin vender option.
    • patrick045
      • Sep 2010
      • 38
      Re: cardreader
      thx please inform how , we are wholesaler company and not very specialized in konica
      thx in advance
      patrick
      • tech51
        • 846
        Re: cardreader
        Might need the key counter link putting back in??
        • patrick045
          • Sep 2010
          • 38
          Re: cardreader
          @ tech 51
          machine came in without card reader , any other solutions ?
          rgds
          patrick
          • tech51
            • 846
            Re: cardreader
            What message are you getting on the panel?
            • patrick045
              • Sep 2010
              • 38
              Re: cardreader
              panel is now showing " please insert key counter "
              • tech51
                • 846
                Re: cardreader
                Then as I posted earlier, the Key Counter link needs to be put back in!!
                • ddude
                  General Troublemaker
                  • 473
                  Re: cardreader
                  I think that this is a 'loop connector' that tells the machine that there is no key counter connected- if you are a wholesaler, you should have plenty of Konica machines available to check this- look for the small rectangular cutout in the machines where a key counter would fit, and see the four pin loop connector attached to the wiring-temporarily place this in your problem machine and see if it solves your problem. Even though the connector is a four-pin connector, the machines usually have a two-pin loop to complete the circuit and satisfy the machine.
                  2000 mockingbirds = 2 kilomockingbirds
