c300
  • wcody76
    • Jun 2010
    • 20
    c300
    hey guys i have c300 fax issue it can receive but cant send ive check the line its ok cause i have a HP inkjet connected that i can send and receive any help would grateful
  • minimerlin
    • 851
    Re: c300
    Are you using the correct fax cable for the c300? Did the machine work correctly and then the fault happened? You have not given much detail for any assistance to be given.
    Please do not PM me without asking first.
    • SKTeK315
      Walter
      • Jun 2009
      • 142
      Re: c300
      Yes he has. He said, " HP fax, (TX & RX) " with no problem.
      Plz try harder. Tnx.
      • minimerlin
        • 851
        Re: c300
        Yes I did read that...BUT that refers to the HP! Not the KM Machine! If the wrong fax cables are used it can cause problems. I also asked if the C300 fax ever worked!
        • nightshade
          Chromographic Supremesist
          • 158
          Re: c300
          I believe that KM uses a 2 wire plug on their fax kits, so you can use any standard phone line 2 or 4 wire and it wont make a difference.
          WCODY if you use the "off hook" mode do you get a dial tone throught the speaker?
          • minimerlin
            • 851
            Re: c300
            I beg to differ, but from experience it is most important to use the correct cable! The wiring is not standard so gives problems. I will now withdraw and watch.
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              Re: c300
              To me it has happened in the past that a line on which an old Canon fax worked perfectly, would not permit the Konicaminolta to receive faxes.
              And 'the result was that the telephone line type' VoIP '.
              Konicaminolta not guaranteed to work on these lines, as are digital. Usually you take down the transmission rate to improve things ...
              ... In the minute that you're thinking of giving up, think about why you lasted so long ...
              • SKTeK315
                Walter
                • Jun 2009
                • 142
                Re: c300
                You are right. Copiers with fax options must use a 2 wire tel cord.
