Bizhub 350, DF 605 jamming
  • SAR
    • Jul 2009
    • 206
    I have a bizhub 350 that is jamming when the paper feeds in. The paper feeds to the triple gray roller and then just stops. It is registering as a transport jam in the counters.
    I have replaced the pickup, feed and sep rollers and blown out the feeder to clean sensors etc. It is an intermittant jam, not every copy.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub 350, DF 605 jamming
    Paul@justmanuals.com
    • jeroen2005
      • 48
      Hello,
      check/replace the torque limitter on the seperation roller assy,tends to turn heavy.Giving too much friction with jams as result.
      • SAR
        • Jul 2009
        • 206
        Thanks for the replies. The problem was caused by a 1 way bearing on the back side of the triple gray transport roller. I took the back cover off of the df and found the 1 way bearing. I cleaned the 1 way and roughed up the shaft and it fixed the problem.
