Transfer Belt Unir on a C450
  • jokacross
    • 110
    Just want to know where I change the fuse of this unit thanks!
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: Transfer Belt Unir on a C450
    If you take the unit out for 20/30 cm can notice on the front side two tiny contacts into a little black cover secured with a little black screw. it contain the fuse.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • jokacross
        • 110
        thanks acusso. one more thing this fuse is the same as the fusion unit? thanks!
        • jokacross
          • 110
          Some one help? thanks
          • CraigW
            • Dec 2010
            • 417
            We have good luck doing the fuser and the belts with 1/16th Amp, 63ma Pico fuses.
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              Same value but different aspect:
              _TBU needs glass fuse.
              _Fuser needs a pico (green) fuse, but you can made something connecting a glass fuse using some wire and tape or similar.
              You can find the original green painted fuse into a plastic tube between the wires under a black cover of the unit
              • jokacross
                • 110
                thanks!!
