I have a customer with a DI550 that says remove copies from the stapler unit when you first turn the copier on. The only way I can reset it is to unplug the finisher then plug it back in and reset the code. I have Tried to change out the finisher and get the same results.If anyone has the answer to this problem I would Appeciate the help.
Thanks In advance
Thanks In advance
