Scan Accelerator
  • dogsbody
    • Jun 2007
    • 289
    Scan Accelerator
    Hi Everybody,
    Was recently asked about scan accelerators for the bizhub mfp's by the sales guys, when I thought about it all I know about them is what the name implies.
    Do any of you guys have them installed in your machines? Do they they make a noticable difference? I'm interested in what everybody has to say regarding them (or any other extra like card/bio authentication etc).
    Cheers
    The force will be with you always.
  • bgbas
    • Feb 2007
    • 60
    I was curious about that to, but all I hear are crickets.
    • fixerboy
      • Nov 2006
      • 17
      Scan Accelerator
      I want to help ... But first what are you trying to do just scan or are you looking for an enhance scanning using what method SMB,FTP or pagescope box operater
      • fausto1981
        IT Technician
        • Dec 2007
        • 146
        I don't know much about Konica but maybe decreasing the resolution on the settings can increase the speed.
        • dogsbody
          • Jun 2007
          • 289
          The Scan Accelerator is an option for some bizhubs (SA-501 - Scan Accelerator Kit for C252 for example). It was just a general question regarding their worth, i've seen one in the field on a machine that does very little scanning. I was asked about them by the sales guys and thought I'd get peoples opinion on them because I have had very little exposure to that particular option.
          • Scott_Lewis
            • Mar 2007
            • 519
            The SA-501 and another one I've seen has what looks like a hardware accelerator board that probably speeds up the conversion of the scan from native format to JPEG format. I suspect it will also allow control of the compression or lossiness levels.
            • Christan
              • 37
              SA-501 is basically a "JPEG board". Without SA-501, scan files using "JPEG compression" but uses"software processing", Bizhub with SA501 uses "hardware processing". Hardware processing is more powerful
              The difference in processing speed with and without SA-50l.
              bizhub C550
              <HDD TWAIN>
              Mode: Full Color
              Format: PDF
              Resolution: 600dpi
              of Pages: 58
              Without SA-50l 564.5 seconds
              With SA-50l : 165.8 seconds
              Approximately 3 times faster.
              <Scan to FTP>
              Mode: Full Color
              Format: PDF
              Resolution: 200dpi
              of Pages: 58
              Without SA-501 : 77.7 seconds
              With SA-50l : 52 seconds
              Approximately 50% faster.
              Mode: Full Color
              Format: JPEG
              Resolution: 600dpi
              of Pages: 1
              Without SA-501 : 12.5 seconds
              With SA-50l : 9.8 seconds
              • dogsbody
                • Jun 2007
                • 289
                bizhub C550
                <HDD TWAIN>
                Mode: Full Color
                Format: PDF
                Resolution: 600dpi
                of Pages: 58
                <Scan to FTP>
                Mode: Full Color
                Format: PDF
                Resolution: 200dpi
                of Pages: 58
                Mode: Full Color
                Format: JPEG
                Resolution: 600dpi
                of Pages: 1
                Thanks for that.
