Hi guys!
I've got a Konica M. Magicolor 2480 Mf that doesn't detect the toners at all. It displays yellow...magenta...cyan..black toners not installed. I've looked after and also I'd met with the problem befopre with a Magocolor 2400 the crum reader was dirty, just clean and everything was fine ( eventhough just one toner was missing not every toners) So even I clean ( got it out and disambly and reassembly properly )the crum reader it doesn't detect any toner, or I got an guess I should look on the left side wires ( also the coper on the left side on the toners) to clean them, cause the left side wire detect the toner, the crum reader just read out the chips. I've clean everything out.
But nothing happened to a good way..it still doesn't detect any toner. What can be the problem?
Thank you in advance!
