bizhub c220
  • hosbiz
    • 13
    bizhub c220
    Need help please, Bizhub c220 not printing from PC. Also will not print Configuration page ,Demo page ,font list from Control panel.All other functions are working OK. Thanks
  • emujo
    • Jun 2009
    • 3009
    Re: bizhub c220
    Are you able to program the TCP/IP info? If not check to ensure that Network functions are turned on in admin mode (don't ask me for the password). If they are then I would flash firmware to the base level, then back up to current levels. I have also found that turning off the network functions, power on/off then re-enabling these setings has helped with lock ups on some of the previous generations. As a last attempt, get into service mode (again, forget about the password) and initialize your network settings. The C360 family prints/scans out of box so nothing needs to be installed for this to work. If the HDD was added during setup, ensure it is electronically installed and formatted (movie data will need to be re-loaded if you format the drive). Emujo
    • TheOwl
      • Nov 2008
      • 1732
      Re: bizhub c220
      I've seen this on a couple of machines straight out of the box and Emujo pretty much covered it.
      Format the HDD, Initialize the NIC and if it still doesn't come online, then do a firmware upgrade as well. Again, as Emujo said, don't forget to reload your animation data.
      • hosbiz
        • 13
        Re: bizhub c220
        Thanks for the help and info.I will try this on my next visit to the customer
        • Glaander
          • Oct 2010
          • 33
          Re: bizhub c220
          it sounds like the IC chip for printing is not installed. if the ic chip not install, you will not see the printer setting tab.
          • mervyn
            • Jul 2011
            • 90
            Re: bizhub c220
            Machine comes with printing and scanning installed , there is no additional kit to be fitted .
