c300
  • wcody76
    • Jun 2010
    • 20
    c300
    hey i have a c300 where the customer scans a 30 page document and it divides it into many pdf`s is there a setting that need to switched
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: c300
    first the machine needs the hard drive installed
    then set multipage pdf for the default in the scanner.
    • wcody76
      • Jun 2010
      • 20
      Re: c300
      HDD is installed but i cant locate the multipage function nor can i format the drive when i high lite the physical or logical option. and where in the settings can u set or unset the HDD thanks
      • mitchl
        • Apr 2007
        • 501
        Re: c300
        If I recall you can turn the HDD off and on in System 2 in service mode, make sure its on if someone had it turned off the drive probably took a dump a while back which wouldnt surprise me. If thats the case get the exact numbers off the drive and get one on Ebay.
