Bizhub C652 J1730 code
  • sauce_boss
    • Oct 2011
    • 26
    Getting a J1730 code. Only happens out of Tray 3 and is intermittent. May go several thousand copies and then have several close to one another. Machine only has 60k on it and has had about 20 of these jams. I have swapped the 2 clutches in the feed unit and replaced the feed tires and dfpr. Any ideas?
  • bizhub1
    • Sep 2008
    • 230
    Re: Bizhub C652 J1730 code
    They have a updated paper feed frame and actuator for that problem from tray 3. Check the knowledgebase and it shows the updated parts.
    • sauce_boss
      • Oct 2011
      • 26
      Guess I shouldn't just trust searching the knowledge base with the mobile app, as nothing showed up. Thanks for the heads up I will give that a shot.
      • bizhub1
        • Sep 2008
        • 230
        It does come up in the mobile app, like 4th down or so.
