Bizhub C6500 have straight line on main scan in leading edge
  • SCHWARZ
    • Jun 2011
    • 47
    Konica Minolta Bizhub C6500 with Fiery IC-408 has printing result straight line on main scan in leading edge.
    Use thin or thick paper have same result.
    I was cleaning 2nd transfer, change the fixing unit and transfer belt unit, but have same result.
    Anyone can help me please....
    Thank you...
  • Gaffers01
    • May 2011
    • 334
    Re: Bizhub C6500 have straight line on main scan in leading edge
    I have exactly the same problem on C5501,
    I have recently done a first PM on it. (no line for first 10,000 odd prints)
    Yesterday when at the customers I swapped the yellow drum with cyan just to see if problem persisted (I noticed the problem seemed to be with Y) and the line disappeared, feeling very happy with myself I then ran about 10 prints and the line came back.
    I then checked the corona and there was a little white mark on the end block (only just replaced corona's with PM kit) I then cut back the end block and swapped the drum again (magenta drum this time) all seems to be fine know.
    Hope this helps.
    • inutelkamo
      • Jul 2011
      • 143
      what paper type and weight?
      • SCHWARZ
        • Jun 2011
        • 47
        Thank you Gaffers01, i will try your advice
        Inutelkamo: art paper 150gsm and 210 gsm
        • charginga
          u can try change drum black to drum yellow,i think this problem on drum unit
