Problem in Konica 7030
  • Dinos
    • Jan 2008
    • 9
    The message is :
    Please insert key counter
    I can not turn it of from dip switches
  • dogsbody
    • Jun 2007
    • 289
    There is a link that has been removed from the machine to connect a coinbox/cardreader or some other device. Whoever removed the device didn't replace the link plug. Call your local dealer and they should be able to supply and or fit it for you.
    Cheers
    The force will be with you always.
    • CMB
      KonicaMinolta Tech.
      • Mar 2005
      • 457
      its called a jumper. be sure to use the right one. plug in the wrong one and you will blow the main control board.
      • Dinos
        • Jan 2008
        • 9
        Thank you very match, it was just a bad connection of that jumper.
        • bsiap
          bsiapi
          • 10
          Patrioti evgales akri?
          • Dinos
            • Jan 2008
            • 9
            Ναι τελικά δούλεψε το παλιόπραμα.
