Strange Issue on a Biz 210
  • groovy
    • 179
    Hi all,
    today i noticed a strange issue into an imaging unit of a bizhub 210.
    The toner recycling section, under the wiper blade, is making a strange noise.
    I serviced lots of this imaging unit (same of the older konica's 7115) but i never noticed this.
    Someone here can post a pic close to the recycling section on this imaging unit?
    I've replaced the wiper blade, the developer and the drum, but this noise (like bad mylars under the recovery/wiper blade) is new...
  • minimerlin
    • 851
    Re: Strange Issue on a Biz 210
    Is it a squeek? Normally it is caused by the plastic bushes at each end of the shafts in the recycling area. Give them a good clean and a very tiny wipe of lube.
    Please do not PM me without asking first.
    • groovy
      • 179
      Thank you for the reply.
      It's not really a squeak, it's more a rubbing noise.
      (it is difficult for me explain in a foreing language...)
      Luigi - Digitalix Srl
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Was your original call for Black smuges or streaks? You found the recycle section packed? If so the plastic shaft in the recycle section may have broken and be causing your noise. Remove the drum, with the spout on your right, turn the white gear on the left by hand the small black gears at the base of the toner spout should be turning if they are not then the shaft has broken.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • boanda
          • Feb 2011
          • 79
          I have had similary problem, nothing was broken, I replaced three black gears on the right side of developing unit and that works fine for about 15k copies,and starts again,and again,until I replaced whole UI. This problem I had only with BH162/ineo161
          • groovy
            • 179
            So the imaging unit has definively dead.
            Can be replaced with the unit from a konica 7115?
            • mrwho
              Major Asshole!
              • 4299
              Usually when the wheels start getting loose (packing the toner in the cleaner blade) I put a couple of drops of superglue to fix the wheels onto their shafts. Usually lasts longer than just replacing them.
              Mascan42
              Ibid
              • groovy
                • 179
                OK, today i've just replaced the IU with onther one, used but in good condition.
                For my things, i've removed the entire front panel and i've noticed a very big spill of toner lying on the bottom of the copier.
                Performed a hard cleaning and i hope no other spill exists.
                Can the toner supply system be broken?
