C-6752 Code on C220
  • prasad
    • Aug 2009
    • 12
    [Error Code] C-6752 Code on C220
    Replaced MFPB, NVRAM, PRCB, CCDDB, DCPS, Flash Firmware, code out on bootup.
  • Ianizer
    • Jul 2011
    • 380
    I'm certain I'll be sorry for asking this...
    Have you done a Trouble Reset?
    -I
    My name Peggy.
    You got problem?
    • prasad
      • Aug 2009
      • 12
      Re: C-6752 Code on C220
      Yes.
      • Ianizer
        • Jul 2011
        • 380
        Real stumper.
        I found a reference to ASIC200 on the MFP-PWB relating to one of the memory tests. I'd be interested to know what that is.
        -I
        My name Peggy.
        You got problem?
        • prasad
          • Aug 2009
          • 12
          Interesting, hopefully something that relates to my copier. I also replaced the memory while troubleshooting.
          • Ianizer
            • Jul 2011
            • 380
            I'd do a data reset just to scratch it off the list...
            Do you have Konica-Minolta SSD access?
            -I
            My name Peggy.
            You got problem?
            • prasad
              • Aug 2009
              • 12
              Data reset is done and Yes! I have an open ticket with KMBS.
              • Ianizer
                • Jul 2011
                • 380
                I assumed that you had. Probably early in the list...
                Good luck on the open ticket. Wish I had more to offer.
                -I
                My name Peggy.
                You got problem?
                • prasad
                  • Aug 2009
                  • 12
                  The problem is resolved by replacing the Interface Cable P/N - A0EDN14800.
                  • HoonBoy
                    • May 2011
                    • 130
                    I had this code today on a bizhub C280, code kept on coming back together with CF907 code, after dis/re-connecting connectors on MFPB and fax option/mount kit code was gone.... Did a firmware update and testing after that without any problems.... unfortunately code came back in the end of the day... will try your solution...!
                    • HoonBoy
                      • May 2011
                      • 130
                      I resolved the C-6752 code by replacing the flat cable between the MFPB and the PRCB... One week without any trouble.
                      • Michko
                        • Sep 2010
                        • 31
                        I got this error on a C224.
                        Did everything in service manual and the cable that was mentioned here. And the cable from ccd to MFPB.
                        Ended with new PRCB.
                        • Deekay87
                          C-f907 Code on C280
                          ]I had CF907 code today on a bizhub C280, after dis/re-connecting connectors on MFPB and fax option/mount kit code was gone.... Did a firmware update and testing after that without any problems.... unfortunately code came back in the end of the day... will try your solution...!
                          • laitang
                            • Nov 2012
                            • 627
                            Re: C-f907 Code on C280
                            Why not start post?
                            From SM:
                            • fajdoooo
                              • Jul 2014
                              • 18
                              Hello,
                              I also replace MFPB, PRCB, Cabel bethwen them, everithing you mention hire, but I stel have C6752. Any sugsestion?
