bizhub 350 Display Panel Hangs
  • goldencup
    • Nov 2008
    • 366
    Hi, I have bizhub 350 which has a display panel problem. As i turn on the machine, only KONICA MINOLTA appears then i wait for a few minutes, the machine just restart and still only the KONICA MINOLTA appears on the display. I've tried pushing the button on the side and do the TROUBLE RESET, still nothing happens. What seems to be the problem? Thank you very much.
  • SPBE
    • Sep 2010
    • 70
    Re: bizhub 350 Display Panel Hangs
    Are you getting an abort code?
    • mo0651
      • 1054
      Does it have a harddrive? could be a NVRAM. Does not happen often, but it can. Reseat the memory chips on main board. Have had a bad chip.
      • mrwho
        Major Asshole!
        • 4299
        Perform a memory clear:
        1. Access the warm reset button on the right side of the main body to the front of the CF update slot.
        2. After warm reset button is pressed, the machine will reboot.
        3. Wait until the black dot appears on the left side of the Konica Minolta display. Press 3 on the keypad.
        4. Enter the Admin passcode (default 00000000) and press End.
        5. Select Total Clear.
        6. Press Yes and then Enter.
        7. Reboot the machine and verify operation.
        Mascan42
        Ibid
