dialta 450/550/470
  • pedol
    • Jul 2025
    dialta 450/550/470
    i have a problem about copiers,,
    starter out wasted, why is that??
    the solution please ..
    thank you
  • mervyn
    • Jul 2011
    • 90
    Re: dialta 450/550/470
    Same as needing an oil change on a car.
    • pedol
      but after I replace the new ones out as well, only a few thousand sheets of copies
      • mervyn
        • Jul 2011
        • 90
        You need to check if the machine is adding toner , what condition is the transfer charger in ? There are lots of reasons , if you are not a tech you need to call in a trained tech .
        • pedol
          I am a technician,,
          and I have checked all the conditions of the copier and all running normally,,
          only problem is wasted stater ...
          • mervyn
            • Jul 2011
            • 90
            Only thing I can suggest is call technical support , they may be able to help.
            • pedol
              oc..
              thanx
              • JustManuals
                • Jan 2006
                • 9838
                Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads - Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads
                Paul@justmanuals.com
