Hi All
I Have A Huge Problem With A C252 When I Switch The Mach On It Will Display The Hour Glass For A Couple Of Seconds And You Can Actually Hear The Machine Start Up But Before It Can Switch Over To Its Opperational Display The Display Goes Black The Only Light That Stays On Is The Power Light And The Machine Can Also Not Print Nor Fax Or Anything Else For That Matter . Nobody Worked On The Machine Prior To This Problem It Just Came Up .
Please Help .
Please Help .
