KM Bizhub c252 HELP!?
  • charlibravo
    • May 2008
    • 20
    [Misc] KM Bizhub c252 HELP!?
    Hi, I have huge problem and I need some help. I cleaned up (transfer belt, IU-s, etc.) my bizhub c252, but when I go to Print/Copy the entire paper is full covered with blue straps all over. I put the picture in attachement. The second problem is that I cannot do some network adjustement on bizhub c252 because the button is "disepeare"? Please help me, what next I can do to fix this problems?
    Thanx in advance
  • groovy
    • 179
    Re: KM Bizhub c252 HELP!?
    Your cyan IU has dead, please replace...
    • charlibravo
      • May 2008
      • 20
      Thanx for rapid response, one another thing, how do I fix that the network button appear in Bizhub menu?
      Thanx
      • k130
        • Oct 2011
        • 36
        sometime i face this problem, and within 2 minutes, the network menu will appear back. if it does not appear within the time, normally i will unplug the ethernet cable. sometime it work. it happens when you switch off the machine and you quickly enter the administrator mode. i dont know what cause this, probably the machine is refreshing and still in the process requiring permission from the network.
        • charlibravo
          • May 2008
          • 20
          now I had one problem more. Error code C-E002?! How can resolve this?
          Thanx
          • RRodgers
            • Jun 2009
            • 1947
            Yep what he said.
            • RRodgers
              • Jun 2009
              • 1947
              Do you have a Fiery attached to it?
              • charlibravo
                • May 2008
                • 20
                sorry, but I dont know
                • RRodgers
                  • Jun 2009
                  • 1947
                  Is there a box bolted to the back of the machine? FYI a tech would know.
                  • charlibravo
                    • May 2008
                    • 20
                    no
                    • charlibravo
                      • May 2008
                      • 20
                      where I can find Firmware Imaging Toolkit 2006, please help me whit this. I have new firmware but need this tool
                      Thanx for help
                      • remati
                        • 149
                        Thanx
                        You must install the last version of the firmware and if the code cames again ,go to the "service mode and do the HD ""version up""
                        • k130
                          • Oct 2011
                          • 36
                          sorry for the late reply, but no, the machine got no fiery attached to it. thank you
