Problem with Fiery 50c-k Bizhub pro c500
  • Marcohey
    • Jun 2025
    I am having printing problems from my pc on c500. Copies are ok. I reinstalled software for fiery but still same problem.
    Anyone has seen this issue before? attached scanned printing results.
    Any help will be welcome
    PruebaImpres01.pdfPruebaImpres02.pdfPruebaImpres03.pdf
  • empiru
    • Feb 2011
    • 229
    Re: Problem with Fiery 50c-k Bizhub pro c500
    Never had this, but it looks like a poor contact to me. I will encourage you to call a tech, though. Good luck!
    I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
    • TheOwl
      • Nov 2008
      • 1732
      I'm going to go out on a limb here and say that it could be the RAM.
      You have done the right thing and re-installed the OS, but the pattern on the prints looks like noise or corruption. When I looked at the print jobs, I noticed that the smaller jobs only had the lines in one area, but the last file had them across the entire page. Was the second file bigger than the Windows test page?
      The reason I ask this is because you might have a bad address within the RAM and you are only writing to the bad address once a print job reached a certain file size. This is my reasoning to believe that it is the RAM.
      • Marcohey
        I Did it, but tech is not able to find the problem
        • Marcohey
          We Checked the ram and it looks it's ok. the second file it was a text wrote on office, small size.
          • TheOwl
            • Nov 2008
            • 1732
            What about the RAM in the copier?
            • Marcohey
              Test1.pdf
              Test.pdf
              • pepper38_cnd
                Field Service Manager
                • Aug 2005
                • 1075
                What Controler do you have ? Is it an IP921? If so take a look at this and see what you think
                Now into Ip TV KODI Boxes
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  if the machine has been ruled out of the problem,try changing the cable from the Fiery to the copier, if no change i'd be looking to replace the video interface card.
                  The gene pool could use a little chlorine.
                  • Marcohey
                    Yes, it is an IP921v 1.1 Make sense trying installing that pacht. where I can get it?
                    • Marcohey
                      I installed the patch, not changes. Now black is gone !! no more printing black from fiery. configuration page is blank, black do appear in copies and printing reports from key operator black text show ok.
                      PS test page shows black does not come out too. machine have 245,000 copies 25,400 from last maintenance.
                      • RRodgers
                        • Jun 2009
                        • 1947
                        I haven't read the whole tread but under calibration you can choose to remove previous calibration. Or you can tell the fiery to do a full reset (that should fix it) but then you'll have to put all the ip info back into it. And the such.
