c203 making noise
+ More Options
Posts
  • bkamoga
    • Oct 2011
    • 31
    [Misc] c203 making noise
    hullo l have a machine c203 it is making noise from the tonner hopper area
    and l want to open it but its hard any help becz the srvice manual does not have it
    it explained
    thaks
  • big jase
    • Jul 2008
    • 136
    Re: c203 making noise
    its the gears that sit at 45 deg to each other on the transport drive section, you can trace from the rod that feeds from end on waste toner bottle page 43 of parts manual
    If at First you don't succeed remove all evidence of ever trying!
    • Darren King
      copiertech
      • 652
      Also, if you recently changed the transfer belt, make sure the the tape is removed from the waste toner port. It will cause a loud grinding noise if it is not removed before installation.
      Hope this helps.
      Darren
      • SmellsHot
        Head Tech
        • 512
        Is it a loud clicking like noise? If so...it's probably hard/clumpy toner stuck in auger section. A nightmare to get to.....sorry
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • emujo
          • Jun 2009
          • 3009
          Yeah..KM quotes around 6 hours on this repair, but we have shaved about 1/2 that by just running a paper clip down the auger tubes to break up clumps, then a very slim vacuum tube to clean out the mess. I think that all the effort we are putting into the color mods..PPLM, IU Yield enhancements, etc is contributing to the problem, as now the color systems are sitting idle and unless color copies are made that plastic toner is just clumping up. Emujo
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            I have seen a black plastic round disk with numbers etched into it come out of a toner bottle and jam up one of these hoppers. I suspect it's just a freak occurrence from the manufacturing of the toner cartridge.
            In this case complete disassembly of the machine was required as it was jammed in there good and solid.
            • bseeley1844
              • Sep 2010
              • 23
              Have the machine in the shop with the toner pipe clogged. Struggling to clear it out with a paper clip. Also would rather replace the whole assembly to prevent it from possibly coming back does anyone have any tips getting this thing out?
              • emujo
                • Jun 2009
                • 3009
                There are no "tips", even KM can't provide the instructions for removing this. You're best bet is to find a candidate MFP tp pull the assy from, and then start taking notes. This section was not designed for removal. Emujo
                • bseeley1844
                  • Sep 2010
                  • 23
                  Thanks...Once I actually gave it a solid attempt to remove it I changed my mind .
                  Went back to the paper clip and eventually cleared it out. Good solution...
                  • emujo
                    • Jun 2009
                    • 3009
                    We replaced one unit before we came up with the paper clip....NEVER AGAIN!!! There must have been 100 various parts laying around this thing..Did manage to get it back together though. Emujo
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      How does this paper clip solution work?
                      From where do you insert it and do you simultaneously turn the gears at the same time?
                      • rbaldwin
                        • May 2011
                        • 5
                        Can please tell how use paperclip? is there a procedure? i have 2 machines with that problem. I looked waste toner pipe and it looks like you have to take the machine down to frame. Not a good idea in a customers office. So to unclog it do you start from the waste toner side?
                        • scottybbb
                          • Dec 2010
                          • 126
                          Would like to know the paper clip trick for this to.
