Was wondering if anyone could help me out, have been having a problem primarily with my cyan (though it's there to a lesser extent on black too). See attached scan - I'd vac'd out the mylar on the dev unit, cleaned the corona wires/grids and laser windows. The drums/devs are around 80%, though the coronas are about 120%. I've managed to get a good tech but he's not going to be able to see me for a few days and need the machine running meanwhile.
Whilst cleaning the cyan dev of fibres I accidentally reverse wound the roller (which I seem to recall discharges it?). I put it back in and ran a few copies - it was pretty much the same as before but running. I then did auto-gamma/reg adjust but it's giving a 45-20 now.
I suspect this isn't belt walk or anything to do with the reg assy but specifically to do with the dev. Is there anything I can do to get it running again before I can get the tech over or is the dev screwed?
