Having a problem with a C652 w/Fiery. The LAN ethernet port on the Fiery does not light up when plugged into a active network and in turn does not pull a IP address DHCP. The other ethernet port on the Fiery " Copier " lights and is working and so is the ethernet port on the C652. IAny input would be appreciated.
