Thin Dots In The Background Of Documents
  • nizar642
    • Sep 2009
    • 16
    I have a Konica Minolta DI550, It's working fine but the printed documents have some thin/micro dots in the background, Not really that noticable but if i look closely i can see them all over the page.
    What causes this? and how to fix it?
    Thanks in advance.
  • jotunn
    • 609
    Re: Thin Dots In The Background Of Documents
    Yellow dots on background is a normal thing on Konica Minolta (but not only, almost all of new color printers or MFP's got something similar) machines since Bizhub C350 as I remember... This is for security purposes - it's just encoded serial number of machine, date and time when document was printed. You cannot turn it off.
    • nizar642
      • Sep 2009
      • 16
      Thanks for your reply, They're not yellow, The dots are black and very small, they're all over the background of the page like a powder.
      • minimerlin
        • 851
        It may be the usual over toning problem..just starting! Has the dev done 250k?
        Please do not PM me without asking first.
        • jotunn
          • 609
          Gosh, I just realized that question was about DI550 not C550... sorry...
          Is your copy/print grainy in touch?
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Itsthepaper
              Supervisor
              • Dec 2007
              • 91
              If the dots are edge to edge of the paper you could have a toner contamination problem, are your toners OEM?
              If your dots are not showing up on your edge erase section then go threw the charge and T/S coronas make sure thier clean then run F5. Also like the previous poster advised make sure your not over on your developer life. These machines had problems with over toning and it was a challenge to keep them running lean and clean.
              Try running a bunch of sky shots and see if it clears some of the dots if it does definetly go threw the coronas and check developer.
              I can't say I miss DI550. Have some upper fuser claws handy.
              Good Luck
              Love the Job Love the Work.
              • nizar642
                • Sep 2009
                • 16
                Thank you all for your responses, Here is a sample of the dots that appear on the page: http://i.imgur.com/vxax9.jpg
                A
                nd no, the page doesn't feel grainy.
                • minimerlin
                  • 851
                  A
                  That looks like machine requires a good service and dev change, followed by full set up. Has the dev been changed at 250k intervals and as previous post is the toner oem? A bit more info can help us to help you!
                  • nizar642
                    • Sep 2009
                    • 16
                    Regarding the developer:
                    I don't think it exceeded 250,000 prints yet, but the guy who got me the new dev 1.5 years ago didn't fully change it, he just added it to the old one.
                    I think i just printed no more than 70k.
                    Regarding the toner:
                    It's not OEM, but it's compatible and i never had problems with it until now.
                    • eg101
                      • Jan 2005
                      • 131
                      It's either developer or drum. How many copies on the drum?
                      • nizar642
                        • Sep 2009
                        • 16
                        The drum is still new, it didn't even exceed 10k prints.
                        • minimerlin
                          • 851
                          If the Dev was not actually replaced as you say but just topped up, I still think it is the problem. Just topping it up does not work as the machine set up is affected ....even if the set up procedure is done!
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            find a new technician that knows what he's doing
