Bizhub 750 - C2105 error.
  • OutlawTorn
    • Aug 2008
    • 189
    Hey all,
    Had this error over the last few days - never seen it before! Reset the error and removed the transfer/sep unit which revealed two sensors which were absolutely caked in toner so I cleaned them out and also cleaned the whole trans/sep unit as well. Any other ideas?
    I also noticed that the code is coming up first thing in the morning so I have disabled sleep mode to see if this helps it.
    Bloody hate these obscure faults!
  • manuelcorrea
    • May 2009
    • 46
    Re: Bizhub 750 - C2105 error.
    you can disable trans./sep. cleaning function in dipsw settings temporarily, until you can get it to stop dumping.
    • OutlawTorn
      • Aug 2008
      • 189
      That might be worth a shot - is it dipsw 3-4?
      What are the possible long term effects of leaving this turned off?
      Cheers.
      • manuelcorrea
        • May 2009
        • 46
        thats the one ..... the wires wont be getting cleaned at regular intervals
