Can anybody supply me with a PDF or a link or something to view the leaflet that comes with a Konica C500 drum? I have forgotten how to install the blue drum in its holder bracket assembly. For some reason, I had streaks in my magenta, and upon examination I discovered this 1/2 inch wide black ribbon with a metallic-woven backing all wrapped around the blue drum, caught between the drum and the blade. I have no idea what this velvet-surfaced cloth ribbon is, but I can't get it out without taking the drum out of it's bracket assembly, and I forgot how this is done. I need the instructions that come with a new drum, and cannot find any on the internet. Thank you. l
Need Konica c500 drum replacement instructions
Re: Need Konica c500 drum replacement instructions
Thank you, but I don't think so. The drum can be bought as the blue drum only with blade, and installed in the bracket. And I forgot how to do this. I'll have to disassemble the whole thing completely to re-discover the procedure. And I don't want to go through all that.Comment
It's not common to rebuild these drum units, that's probably why not many guys are responding to your post. I appreciate trying to save on parts cost, TOTALLY UNDERSTAND, try katun they have drums much less than Konica Minolta and provide a warranty. When I go to the shop tomorrow I'll take one of my spare drums apart and I'll follow up with the steps I took. I'll also look for the ribbon, I'm curious to see if it is in the drum unit.Love the Job Love the Work.
It's not common to rebuild these drum units, that's probably why not many guys are responding to your post. I appreciate trying to save on parts cost, TOTALLY UNDERSTAND, try katun they have drums much less than Konica Minolta and provide a warranty. When I go to the shop tomorrow I'll take one of my spare drums apart and I'll follow up with the steps I took. I'll also look for the ribbon, I'm curious to see if it is in the drum unit.Comment
The manufacturer designed the drum unit to be replaced as an assembly. In training, they mentioned that the aftermarket would surely come up with a drum and blade only as a retrofit but you get what you pay for. All 4 drum units are designed to be replaced at the 100K PM cycle. They will go beyond that mark but not by much more than 10-20K. If you want it to stay in best working order, follow the PM schedule and quit trying to save pennies that will cost you dollars in the long run...just my opinion. give it whatever value you would like.Comment
OK guys--this is NOT ABOUT the perils of aftermarket materials. We're talking about ORIGINAL EQUIPMENT STUFF that has a strange cloth strap tangled around the metal drum. And I want to take the drum out of its bracket so I can untangle this wierd strap that has gotten snarled around it. As far as I know, this came with the copier with all original drums. I DO NOT need a lecture on aftermarket stuff.I'm 55 years old and have been working on things for 40 years. I know ALL ABOUT aftermarket stuff. Can you help, or not? Read the question please. Thank you.
For end users 40 miles in the middle of nowhere, after-market stuff is our only hope. Even then, these machines are a bottomless pit to throw money into.
Now... can someone please answer the question? Thank you.Comment
The markup is not as great as what you think but lets start over. I have never taken apart a drum unit but I suspect it is a simple "pull the bearings and slide it out" operation. Should be no big step with your experience.
I worked on 1 machine of that frame. An 8050. It was delivered shortly before, and I was in training during the super bowl with Janet Jackson's "wardrobe malfunction". That is my only reference of time on that machine. It is semi-retired now and has clocked close to 10M prints. You are correct in the statement that 100K PM cycle is ridiculous but the engineers did not ask me. I just followed the PM cycle as best as I could and followed up with other failures as they came up. Konica "whored out" this product to everyone including Pitney Bowes as a "digital press". Truth is, they tell me that the C500 was a step backwards from the 8050 and the machine's day has come and gone. I wish you luck in making your fortune with the one that you have. Technology has made huge strides forward since your machine rolled down the assembly line.
Again, I do not know what is wrapped around your drum and have not taken apart a drum unit short of installing new gears on an out of the box drum unit that came in damaged. But I am confident that you will get the drum out and clear the "obstruction". It was my understanding, and I took it on faith that there was a lube bar in the drum unit that would not be addressed by the aftermarket and that a simple drum and blade change would be "whizzing in the wind".
Good Luck,
G.H.Comment
Good Luck,
G.H.Comment
If you can't take apart a C500 drum then your not much a technician, sorry to tell you the truth. The C500 is the worst machine for a print shop enviroment and the cost to keep that thing running is out of control PM kit at a 100k then another at 200k, yea no wonder your not making any money.
Don't blame democracts and computers on your failure as a business owner, try to tone down the attitude if your going to ask for help on this board.
Get rid of the C500 and get something else to run your 4 color work. Just a tip from a democract, Mr know it all that can't take apart a drum unit.Love the Job Love the Work.
