Hi, it is MIESSAN I have some problem with my machine. It displays error code F35-4 or F10-1. I want to know the meaning of these codes to repair my machine. It is urgent. thanks!
F10-1 : Failure in serial communication between the PRDB (printer drive board) and CB (overall control board).
Correction:
Switch SW2 (sub power switch) OFF and then back ON.
F35-4 : TH2 (fixing temperature sensor 2) detected abnormally low temperature.
Occurs if L3 (fixing heater lamp 2) remains energized for longer than 10 seconds during idling state.
Correction:
Set SW2 (sub power switch) OFF and then back ON, after set to "0" the bit 1 in DIP SW3 in 25 mode.
(If you switch power back on without releasing the latch, the error will recur.)
Correction:
Correction:
