just got this error code C-3102 book said not in home pos. look at sensor and cam was turning then stops each time is there any thing
i can do to get it runging
thanks
Yes, on the left hand side there are 3 white 1 way gears all the same size, 2 together and 1 below. I normally clean them up and if that doesn't work replace them and the shaft that has the 2 gears on it.
