konica3331 error code 10-01
  • cliffhangers
    • Feb 2010
    • 243
    Hi,happy new year,please this Konica3331 is displaying error code 10-01 i need help on this error code.THANKS IN ADVANCE.
  • JustManuals
    • Jan 2006
    • 9838
    Re: konica3331 error code 10-01
    Paul@justmanuals.com
    • mrwho
      Major Asshole!
      • 4299
      Check the following:
      - Is the lower fusing roller stuck or binding? Is the fusing unit hard to turn by hand?
      - Is any corona arcing? Take out the TS corona and run a copy; if the error doesn't ocur, then the TS corona can be the culprit; if the error still ocurs, then check the charge corona.
      - Check the operation lcd panel (check the CN11 and CN13 connectors). If doesn't solve, try another panel (good luck on that one, do you have more than one dinossaur still operating?)
      Good luck!
      Mascan42
      Ibid
