Minolta EP 1083
  • olsen
    [Jamming] Minolta EP 1083
  • minimerlin
    • 851
    Re: Minolta EP 1083
    The normal reset after a jam is to close the front door as the last action after closing all other open parts! Make sure the actuator on the door is not bent, also look for a broken plastic exit actuator on the guide section just after the fuser, it is easy to break the shaft on this bit! There is also a chance that the right hand side door closed sensor is knocked out of position. Did the machine show a jam during a copy run? Did you find any missfed sheets?
    Please do not PM me without asking first.
    • olsen
      Re: Minolta EP 1083
      Hello and thank You so much for your quick reply. I looked for any of the faulth mentioned. No luck - BUT then I opened and closed the front door with the power on. And suddenly the red light disappered and the mascine could start again.
      Thank you so much for your help
      • minimerlin
        • 851
        Re: Minolta EP 1083
        Your very welcome, you may have a problem with poor take up from the trays which can give jam indication you mentioned. Also make sure the machine control panel reports the correct paper that is in the trays as this is another possible cause.
        • JustManuals
          • Jan 2006
          • 9838
          Re: Minolta EP 1083
          Paul@justmanuals.com
