6501 c-0322
  • jrider
    • Aug 2025
    [Error Code] 6501 c-0322
    6501 is throwing (M67) fan abnormality detection signal code c-0322.
    Is there a quick way to either bandaid the issue or to determine which of these two to replace?
    "Conveyance drive board (CDB)
    ADU fan /2 (M67)"
    any assistance would be appreciated
  • Herrmann
    • Jan 2006
    • 792
    Re: 6501 c-0322
    First at all, you should check the adu fan itself, maybe it is blocked by paper debris or something. Then do an I/O check; the check code is 42, the multi code is 20 for m67. Third, remove the left adu cover and attach a meter to the wires of the fan, it needs 24v, are they there when fan is activated?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
