KONICA MINOLTA C500
  • copierlady
    • 338
    KONICA MINOLTA C500
    I am working on two c500's . The first one has an external fiery hanging off the back of the machine that uses two pig tails to connect it to the machine. I can print to that one.
    The second one has a fiery that is built into the back of the machine. I am using window 7 opperating system. I can not seem to connect to that machine. Can anyone tell me what drivers i need to download to connect to that machine? What is different from the other machine that is keeping me from printing?
    Networking is not my thing. Thanks.
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: KONICA MINOLTA C500
    http://www.copytechnet.com/forums/ko...921-setup.html
    No w7 driver available...try a Vista driver and good luck
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • copierlady
      • 338
      I installed the driver. I can ping the printer. I can get in with explorer. It will not print. I'm doing something wrong. It must be windows 7.
      Any ideas?
      • sanimir
        • 183
        Try it first with an older system,
        This is easiest way to see how and what next.
        Also see whether the network cable into the right port.
        I knew I had to cheat and plug the cable into the connector of the printer instead of a Fiery.
        • logrady2331
          • Feb 2011
          • 301
          Could be they both had the external Fiery at one time. Make sure the controller type is set correctly. Don't remember which one it is (1 through 5) but I woud look there.
