DiAlta Di200 - network card problems
  • smart-refill
    • Jan 2012
    • 27
    Hello
    I have a Di200 with Pi3502.
    Today I tried to print with my Di200 for the first time.
    The protocol address of Di200 is 10.233.21.108. Today I realized a short network with my PC and Di200. (the PC has 10.233.21.101 protocol address)
    When I tried to ping from my PC ping 10.233.21.108 errors returned. sometimes the ping was ok, but most of the times the ping retuned errors.
    I did not menage to print a test page.
    Can anybody help me?
    Thank you!
  • RRodgers
    • Jun 2009
    • 1947
    Re: DiAlta Di200 - network card problems
    Originally posted by smart-refill
    Hello
    Thank you!
    I believe those little PI's are little external fiery print controllers. Those are kinda known for the HDD's to go out on them after a couple/few years. Can you get to the network settings from the copier? Maybe try a ping 10.233.21.108 -t and let it run to see if it pings over a given time of about 3~5 mins. If it pings then stops then pings then stops it's the fiery stuck constantly rebooting and probably time for a new hard drive and OS reload.
    • Hansoon
      • Sep 2007
      • 3347
      Bad news. Those NIC's go bad by aging. No replacement from the factory since years. About a million posts here in this forum about that issue.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
      • smart-refill
        • Jan 2012
        • 27
        Thank you Hans!
        I will try to print using the parallel port.
        Best Regards!
        Sorin from Romania
