error code c0070 minolta buiz hub 163
  • RWAFA
    • Aug 2011
    • 68
    hi guyz,i have my minolta buizhub 163 and its showing error c0070 it only produces1 copy then the msg apea c0070
  • ck1
    • 485
    Re: error code c0070 minolta buiz hub 163
    Check the hopper toner sensor . Maybe dirty .
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • donncius
        First of all check toner bottle installed correctly, if it's ok you need to take out all hopper section and check white pin (4021 5315 01) located on motor it can be broken, if it is ok change motor (9312 1100 13). if motor doesn't help try to change all hooper section.
        • RWAFA
          • Aug 2011
          • 68
          thankx guys its done.
          • malthus
            • 29
            check condidition of nipple ontoner bottle if damaged replce bottle .also customer may have twisted moter while inserting bottle remove front cover and check spring for toner rotationlock if out of position refit otherwise toner moter has been damaged internally replace
