Konica Bizhub 350c receiving jobs but just printing snippets, surrey england
  • jack pease
    • Feb 2025
    [Misc] Konica Bizhub 350c receiving jobs but just printing snippets, surrey england
  • Gaffers01
    • May 2011
    • 330
    Re: Konica Bizhub 350c receiving jobs but just printing snippets, surrey england
    Hi, It sounds like you have the wrong print driver to me, check that first.
    If you havent go to the konicaminolta website where you should be able to download the right one.
    • jack pease
      Thanks - i've tried pretty well every driver i can find from US and UK, the one i've spent most time on is the C350PCL5cWin2000WinXP_110gb.exe (316 Kbytes) one which at least means i get paper out of the machine, albeit with a few letters dotted here and there
      There's a 'universal' driver on the UK KM website but that doesn't work, the read me says it deals with 'all' bizhubs and then lists them (clipped below) but not the c350, only the 350 which is black and white. Aaaaaaghhhhh. I ONLY want to print A3, if that means i can use a workaround?
      thx
      J
      Baseline (1.0.1.UPD_04)*1 1.0.1.UPD_04
      KONICA MINOLTA 163/211 (1.0.1.UPD_04)
      KONICA MINOLTA A3 common (1.0.1.UPD_02)*3 1.0.1.UPD_02
      KONICA MINOLTA mc8650 (1.0.1.UPD_02)
      KONICA MINOLTA A4 common (1.0.0.UPD_01)*2 1.0.0.UPD_01
      KONICA MINOLTA C30P/C31P (1.0.0.UPD_01)
      KONICA MINOLTA C20 (1.0.0.UPD_01)
      KONICA MINOLTA C20P (1.0.0.UPD_01)
      KONICA MINOLTA 40P (1.0.0.UPD_01)
      KONICA MINOLTA mc5550/mc5570 (1.0.0.UPD_01)
      KONICA MINOLTA mc5650/mc5670 (1.0.0.UPD_01)
      KONICA MINOLTA mc4650 (1.0.0.UPD_01)
      KONICA MINOLTA mc4695MF (1.0.0.UPD_01)
      KONICA MINOLTA pp4650/pp5650 (1.0.0.UPD_01)
      KONICA MINOLTA mc5450 (1.0.0.UPD_01)
      KONICA MINOLTA 500/420/360 (3.0.2.UPD_02) 3.0.2.UPD_02
      KONICA MINOLTA 501/421/361 (2.0.1.UPD_02) 2.0.1.UPD_02
      KONICA MINOLTA 750/600 (3.1.0.UPD_02) 3.1.0.UPD_02
      KONICA MINOLTA 751/601 (1.0.3.UPD_02) 1.0.3.UPD_02--MFP FW ver.19
      series or older
      KONICA MINOLTA 751/601 (2.0.0.UPD_01) 2.0.0.UPD_01--MFP FW ver.20
      series or later
      KONICA MINOLTA C650/C550/C451 (6.3.0.UPD_03) 6.3.0.UPD_03
      KONICA MINOLTA C450/C450P/C351 (1.0.0.UPD_03) 1.0.0.UPD_03
      KONICA MINOLTA C352/C352P/C300 (1.0.1.UPD_02) 1.0.1.UPD_02
      KONICA MINOLTA C250/C250P (1.1.1.UPD_03) 1.1.1.UPD_03
      KONICA MINOLTA C252/C252P (1.1.1.UPD_02) 1.1.1.UPD_02
      KONICA MINOLTA C353/C253/C203 (6.3.0.UPD_03) 6.3.0.UPD_03
      KONICA MINOLTA 350/250/200 (1.1.2.UPD_02) 1.1.2.UPD_02
      KONICA MINOLTA 362/282/222 (1.1.0.UPD_02) 1.1.0.UPD_02
      KONICA MINOLTA C652Series (3.0.16.UPD_01) 3.0.16.UPD_01
      KONICA MINOLTA C360Series (3.0.16.UPD_03) 3.0.16.UPD_03
      KONICA MINOLTA 423Series (1.1.2.UPD_02) 1.1.2.UPD_02
      KONICA MINOLTA 652/602Series (1.1.0.UPD_04) 1.1.0.UPD_04
      KONICA MINOLTA C35 (1.1.2.UPD_02) 1.1.2.UPD_02
      KONICA MINOLTA C35P/mc4750 (1.1.2.UPD_02)
      KONICA MINOLTA C25 (1.1.2.UPD_02)
      KONICA MINOLTA 20P (1.0.0.UPD_01) 1.0.0.UPD_01
      KONICA MINOLTA 20 (1.0.0.UPD_01) 1.0.0.UPD_01
      • Gaffers01
        • May 2011
        • 330
        Hi again,
        I have attached a link to where I know the printer driver works as I used it at a customers at the beginning of last week.
        Download Center - Support | KONICA MINOLTA
        Choose multifunction colour, then choose the C350 it should then come up with the XP driver and try that.
        • JSC
          Gimp
          • Dec 2006
          • 618
          If this is a biz C350 do you have the Fiery connected to it? if you do you need to use the fiery driver which is the IC401 (I think)
          The gene pool could use a little chlorine.
          • jack pease
            No fiery, I thought i could get away with PC direct to bizhub using PCL5e driver - what you lose is the ability to send it postscript? Sure, fiery makes it more flexible, but if on a budget and working just me in my shed, no fiery is fine isn't it?
