minoltadialta cf1500 error code C0500
  • cliffhangers
    • Feb 2010
    • 243
    HI,this minoltadialtacf1500 is displaying error code c0500 when i clear the error code it will be okay for some time letter on the code will show again,they toll me is thomofuse and i don't have that same thomofuse so i remove it from another copier that looks alike and put on minoltadialtacf1500, when i on the copier it will booth when it one to get ready for copy it will make a sound kik and return error code C0500, then i try to link the one i remove from the copier and put it as i have been doing to other copier bet it will warm up well and one to copy it will get back to the same error code C0500.please i need advice on this problem.thanks.
  • Tec1
    • Dec 2011
    • 48
    Re: minoltadialta cf1500 error code C0500
    you replaced thermal fuse or thermistor?
    or both?
    I'd just replace the whole unit
    • stedros
      • Oct 2011
      • 34
      YOUR MACHINE might have got some power surge try to TROUBLE RESET hope it will workout
