Bizhub c451 firmware update software / procedure
  • mojorolla
    The Wolf
    • 2627
    [Misc] Bizhub c451 firmware update software / procedure
    Let me say straight off, I am not begging for firmware.... I have been tasked with updating firmware on a c451. I cannot find the software for writing the compact flash card on the mykonicaminolta site. I have done update before on the older bizhubs and it was files on a card with a FAT format. From what I can gather, the c451 has a tool called "Firmware Imaging Toolkit 2006" used to write the firmware to the card. So I guess I have 2 questions:
    1. Do I need the writing software for a c451 upgrade?
    2. If so, where the hell do I find it on the mykonicaminolta site?
    Thank you in advance.
  • Eresources
    • Nov 2011
    • 37
    Re: Bizhub c451 firmware update software / procedure
    Search for it within the CSES "Search Information" with the wording "Firmware Imaging Toolkit". It's third on the list on my screen.
    • emujo
      • Jun 2009
      • 3009
      If you're still having trouble finding the software, PM me with your tech ID. If you're legit, I'll send you via email, or send the link. Emujo
      • mojorolla
        The Wolf
        • 2627
        First off, thanx for the responses.
        I have tried 4gb, 256mb cf card and a 128mb cf card. I have tried using the firmware tool and the command prompt to write the files to the card. Each time, I get an invalid card error at power up. The first call to the hotline, I was told I need a 256mb card. I got one and tried that, same error. Called the hotline a second time and was told to use a 128mb card. When I pointed out that it clearly says this model needs a 256mb, I was told "don't listen to what is in the manual". So I went out and got a 128mb card. Try finding one this size locally. So I went back today with my 128mb card and guess what happened, same error. The third call was almost 2 hours long until I finally got through to a senior tech. He said the card needs to be formatted in vxWorks. I mentioned this feature was grayed out in the toolkit and he said so was his and didn't have an answer for me. He basically said I am screwed until their cards come off of back order; which has no ETA by the way.
        That being said, I have more faith in this forum, as always, than what I am hearing from tech support. So I have 2 questions:
        1. Being a first time caller, is it normal to get half a dozen different answers from KM tech support regarding the same problem?
        2. What are the specification of the compact flash cards. Manual says FAT format, tech support says FAT32 or vxWorks.
        • Eresources
          • Nov 2011
          • 37
          I usually put the CF memory card in the PC, run the firmware imaging toolkit, format the card in FAT using the firmware imaging toolkit, load the firmware using the firmware imaging toolkit, plug it into the copier and boot from it.
          I use 256MB Sandisk cards as any larger than that won't work with the firmware imaging toolkit.
          Other than that you might have a faulty mainboard.
          In answer to your first question, Yes sometimes. Due to the different experiences those techs have had.
          • emujo
            • Jun 2009
            • 3009
            once a CF card is formatted "FAT" it typicaly can't be used in a color MFP. The only way around this is to find a hex editor tool and write "0"s to the card. This makes the card "out of the package". When you use the firmware tool kit, part of the process is to install the VXWorks format. One way to determine if the tool has worked correctly is to try to look at it with your laptop after you write the firmware. If it's correct you should get a message "the card must be formatted to continue" or something to that affect. If you can read the card with your laptop after you write to it the previous FAT structure is still on the card. BTW, I've asked a few time why the "VXWorks" format selection is greyed out, but no one seems to have an answer. Emujo
            • Rvale
              • 83
              • rrrohan
                • Sep 2011
                • 1977
                i hate having to mess around with CF cards
                just host a FTP server on your tech laptop and use ISW
                • 907tec
                  • 434
                  • Synaux
                    • Mar 2012
                    • 1224
                    I would buy a new card get a san disk shoot and store card (not all cards will work).
                    Its on amazon here for 39.00, but can probably find it cheaper.
                    Never format the card if you want to be successful and dont worry about the option being grayed out in the toolkit. You simply tell it to write to the card and it does everything for you and you can compare the checksums to make sure the files were written correctly.
                    • Rvale
                      • 83
                      nvram clear
                      By the way, have anyone already tried to use the nvram clear on those machines and after the reboot it started working again, thankfully without passwords but with squares all over the copied image? Like preventing it from been resalable. It seems to have some sort of certificate failure but doesn't give me any sort of error messages like the ones whe got when changing the nvram itself with another equipment.
                      I inserted the new serial nummber on the tech menu but didnt help.
                      • Zeldaman
                        • Mar 2011
                        • 946
                        Hi there!
                        You must do the complete setup (in the right order!!), as if the machine is fresh out of box.
                        Greetings...
                        • Rvale
                          • 83
                          Sorry to bother you once more, but as i've never installed a brand new c451 could you please point me where can I find the installation procedure, i couldn't find nothing but the unpacking procedure and the SM on the partner portal.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            The installation guide is a separate document.
                            Those squares are normally lines.
                            I think the key items are
                            Touch screen calibration
                            Gradation adjustment
                            Date and time
                            Try that, if no luck I will link the install guide tomorrow when I'm in office
                            • Synaux
                              • Mar 2012
                              • 1224
                              Do these in this order:
                              Touch Panel Adjustment in Accessibility settings
                              Gradation Adjustment in Service Mode
                              Date/Time setting in Service Mode
                              Date/Time setting in Administrator Mode
                              Enter Install Date in Service Mode
                              Serial Number Input in Service Mode
                              List Output in Service Mode
                              I have been able to skip some these with success, but I cant remember which ones, so take a few extra minutes and do them all.
                              Note: If the ioption crap is installed (e.g., lk101-103) and you get a "license error" you will have to get a certified tech to re-validate it.
