Konica Minolt Bizhub C 352 CYAN TROUBLE
  • sakisaki
    • Aug 2025
    Hello guys,
    I have been having trouble with my Bizhub C 352. I fixed it like a month ago and then i went on holidays.
    The machine was in my workshope. When i came back i found out that the machine was having alot of problems.
    When i print with the original IU, it prints the blue color all over the page and when i change the IU the blue or cyan simply
    dissappears.
    When i turn my machine on, after warmimg up it gives me 2 codes.
    P 6 and few seconds later P 21.
    Now i have tried to change my IU and Print head and even the assembly belt but i failed with everything i tried.
    I would really appreciate some help here.
    Please forgive my english, it isnt really my strong point.
    Hope to hear from the masters soon.
  • Zeldaman
    • Mar 2011
    • 946
    Re: Konica Minolt Bizhub C 352 CYAN TROUBLE
    Hi there!
    It can be a bad MFP-Board, but my first thinking is to check the contactsprings of the high-voltage-unit.
    If they are not 100% in the correct position you get the phenomens you described.
    Greetings...
    • sakisaki
      Hello,
      Thanks alot for your fast reply.
      another fact that i forget to mention was that.
      Last time when i fixed the machine it was working fine, then i left for my holidays and during that time it was extremely
      cold and temperatures went upto -5. So is it possible that low temperatures might have damaged something?
      i am going to try the things you mentioned right now and will inform you as soon as i have tried it.
      what does MFP stands for? sorry we have different names in german
      • Zeldaman
        • Mar 2011
        • 946
        • sakisaki
          Hello,
          Thanks alot for your tips my friend it worked finally
          Ok here is what my problem was.
          I fixed the machine but when i returned from my holidays, the machine was printing alot of cyan all over the page, thn i changed my
          IU and the problem changed, it was printing no blue at all and after the warm up phase it was showing me P-6 and P-21 codes.
          So i replaced IU, Transfer Belt and PRINT Heads but the problem wasnt going away.
          So thn i did what you told me to do. I opned HIGH VOLTAGE UNIT and cleaned it and all the contacts with including the springs with clean tissue, put it back together.
          after that i took all the cables out from MFP board (which i know as a mechanica control board) and i put them slowly and carefully back inside.
          Turned the machine on and it was working.
          So thanks alot for your help.
