Have 2 different Bizhub 750's that have prematurely developed scratches on the operator side or front side about 2 inches in from the end, and both machines seem to have the same type of scratches in the same area. It ends up being on the bottom inch of an 8.5x11 sheet running thru the machine landscape direction.
Looks as though something either in the drum carriage or transfer assembly is rubbing against the drum causing scratches around the circumference area. Checked all around drum carriage and transfer guide and corona and can't see anything touching it. Anybody ever see this, need suggestions???
