Secure Print Jobs With Linux to a C280
  • oldschool
    • Mar 2007
    • 245
    We have a customer that wants to charge for print jobs at the copier op panel. That is normally done with Vendor 2 and sending a secure print job. The customer is using a company called Userful. This is a Linux based product. There are drivers for Linux at the Konica Minolta website but The Tech onsite is being told that the option to send a secure print job isn't available in the Konica Minolta Linux driver. I don't have a Linux box to test with. Does anyone else have experience with a Linux printing to a C280?
    Thanks?
    Jamex Tech Support: Saving the world one phone call at a time.
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Re: Secure Print Jobs With Linux to a C280
    I've had very little success with secure print on the mac and linux drivers. I've been able to make it work situationally, but its inconsistent at best.
    Parts: Its what your copier craves!
    • oldschool
      • Mar 2007
      • 245
      The tech onsite has loaded the drivers with Userful's support but no secure print feature.
      When you did get it to work was it something like editing the ppd files or was there some other work around.
      • dallas
        • Jun 2008
        • 115
        The only way I know is to use KMPU (Print Utility for Unix).
        KMPU supports Secure Print, User Authentifikation, Account Tracking, Box Printing ...
        • TheOwl
          • Nov 2008
          • 1732
          Using the Konica Minolta Print Utility for Unix should help solve this issue.
          Once you have the software installed, please make sure that you then install the C220/C280/C360 PPD and configure the software by using ./kpconfig -a
          Once configured, you then need to use Kp for printing which then uses everything configured in Kpconfig as a default or you can print using Kpp which should give you a GUI version of Kp.
          Download the software and you will find everything in the manual.
