Konica 7222 Error code N-15
  • dabearsdabulls
    I am having a struggle getting the scan to email working on this Konica 7222. Everything in the settings seem correct but when I scan it shows an error of N-15. Nothing in the manual shows this error. Any suggestions would be appreciated.
    Thanks,
    Steven
  • 173545
    • 16
    Re: Konica 7222 Error code N-15
    Solution ID TAUS0638997EN00 Solution Usage 0
    Description
    N-15 code and various other N codes when scanning to E-mail, using PDF* format, after five (5) pages or more. E-mail is received as a data dump instead of
    a text message.
    Solution
    CAUSE: Binary Division is set to ON in the SMTP settings for the printer NIC.
    SOLUTION: To disable Binary Division, perform the following:
    1. Browse to the printer NIC and select Network Settings.
    2. Select E-mail Send (SMTP) Configuration and then disable Binary Division. Enter the password and click OK.
