According to the book there is no fatal error 144 but 14H is listed as follows:
14H:
2nd image transfer pressure/retraction failure
Relevant Electrical Parts
Retraction Position Sensor /2nd Image Transfer
(PC5)
Pressure/Retraction Solenoid /2nd Image Transfer
(SL4)
Main Motor (M1)
Mechanical Control Board (PWB-A)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
1
Check the M1 connector for proper connection
and correct as necessary.
2
Check M1 for proper drive coupling and correct
as necessary.
3
Check the SL4 connector for proper connection
4
Check the PWB-A connector for proper connection
5 PC5 sensor check. PWB-A PJ14A-3 (ON) 2-G
6 SL4 operation check. PWB-A PJ11A-2 (REM) 2-G
7 M1 operation check.
PWB-A PJ8A-5 (REM)
PWB-A PJ8A-8 (LOCK)
2-G∼H
8 Change PWB-A. - -
Thanks, you read my mind. I was faxed a handwritten note and misread the 14H as 144. I don't even work on Konica/Minoltas so I didn't even realize.
14H:
(PC5)
(SL4)
Main Motor (M1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
1
2
as necessary.
3
4
PWB-A PJ8A-5 (REM)
PWB-A PJ8A-8 (LOCK)
2-G∼H
8 Change PWB-A. - -
