7155/65 warming up, no code
  • superfly
    "Can i make a quick copy"
    • Dec 2007
    • 16
    I thought i would share this with you guys-
    If you ever run into one that constantly says 'warming up' and never comes ready or throws a code, the fuser connector in the back of the machine is likely broken.
  • CMB
    KonicaMinolta Tech.
    • Mar 2005
    • 457
    or one of the heater lamps is burned out, or a cover is open somewhere??? my starting point would be to remove the lamps and ohm them out.
    • random
      • Pini9061
        7165 FAIL
        if you have this code try to replace the TLD sensor under the drum
        best reg
        pini
        • Sjeuf
          there is a microswitch under de fixing release lever ,confirm the right position of the lever,if this is good, check de switch good luck
          • CMB
            KonicaMinolta Tech.
            • Mar 2005
            • 457
            i believe you are thinking about the 7050/7055. a 7155 does not have that switch.
