IP-511TypeA Print controller fimware patch
+ More Options
Posts
  • brahim2222
    • Dec 2011
    • 9
    [Error Code] IP-511TypeA Print controller fimware patch
    how to update firmware for IP-511TypeA Print controlle i have 2 file ip511A_2643.bat and ip511A_2643.pkg
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Re: IP-511TypeA Print controller fimware patch
    First of all understand what you have there is a firmware patch. This is meant to a be applied to a working IP-511A that already has Firmware Version 23.0 or higher if this is not your situation then don't do anything or you will brick your IP.
    If this is your situation just connect your PC to the parallel port with an ieee compatible cable go into Printer setting mode and run the bat file on your PC, when you get an update successful message turn off machine disconnect cable and restart machine.
    Note patching an Ip that is not opperating propperly will rarely repair it, the IP-511A has been arround so long now that it is not likely yours need patching if you need to restore the firmware or reload the firmware or replace the HDD that is a whole different story.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
