Code means that there is an insuffcient amount of toner in the Black IU. The IU have been replaced twice. The TCR for the black shows a low level, where as the TCR for the rest of the colors are fine. If you run the auto toner supply for the black it will take up to 10 mins before it finishes. You could then run around 13 copies and then the code reappears.
Im suspecting that there is a problem with the K toner hopper.
P.s. the Serial Number was inputted and the mylar on the toner bottle was removed per Konicaminolta recommendations.
I'll visit this machine tomorrow (Friday)
Anyone seen this problem?
